Phioco 90 Power Transformer Wire Colors
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 single 47 radio.  I have been searching to find the wire colors for the power transformer and although there are several threads that cover the subject, I have not found any with complete information.  So I have done my best to ascertain the actual wire color and types in the unit I have.  This is what I have found and I hope some find it useful.
Primary - White 14 ga.
Rectifier HV - Yellow 16 ga.
HV center tap - Yellow with 3 strand blue tracer 18 ga.
Rectifier filament - Blue 16 ga.
47 tube filament - Green 16 ga.
47 tube filament CT - Black with 3 strand green tracer 20 ga.
Other filaments - Black 18 ga.
Other filaments CT - Black with 3 strand white tracer 20 ga.
This is all cloth covered wire and can be found at Rhode Island Wiring Services, YNZ Yesterdays parts, and Antique Electronic Supply.  The number of threads in the tracer may be one or two rather than three and 20 ga. is not available from RIWS or YNZ.  18 ga will substitute nicely.
Thanks for adding that information.
Ok.... In the fourth year of the war, I still decided to return to an active hobby. For more than three years, I did not...RadioSvit — 10:43 AM
Philco 37-116 Cabinet Repair
You'll probably have to get quite a large amount of wax filler, those are some big gaps, and both sides. Nice summer pr...RodB — 10:38 AM
Hello everyone. I completely agree with Richard and Dan - in this case, without replacing the veneer, only a wax filler ...RadioSvit — 10:07 AM
I have used Timber Mate Timber mate is a grain filler  . You can get it in different colors,so it will be close to...Dan Walker — 09:51 AM
Help with Supreme 599
The 300 ohm line adjustment is used to set the primary of the transformer to a nominal voltage for any line voltage from...DaleHCook — 09:22 AM
I think Arran is correct about the substrate expansion. I'm going to give the colored wax a try.dconant — 08:11 AM
Hello Guys, What I would do is get  colors of wax filler and fill in the void ! Sincerely Richardradiorich — 12:41 AM
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
There are currently 1013 online users. [Complete List]
» 3 Member(s) | 1010 Guest(s)
