Philco 32-7981 audio output transformer replacement
I am replacing a philco 32-7981 audio output transformer with an open primary in a 41-315X. I have read in this thread, https://www.philcoradio.com/phorum/showt...p?tid=9968 , that a Hammond HX-125D is a possible replacement.
The post goes on to say "Edit: You won't find a new transformer that has the feedback tap in the secondary which the original had. But that can be worked around; we can tell you how when you get your new transformer."
I never did see the work around for the feedback tap.
Can anyone explain please?
Glenn
Unfortunately the person who wrote the "Edit" was Ron Ramirez who is no longer with us. Perhaps someone else can help sort it out ... ?
Bob, very sorry to hear that. From the few posts of his that I have read, Ron seemed to be very knowledgeable and willing to share.
Glenn
Yes, he surely was! We miss him very much.
Hello Glenn,
Yes, the 125D or E will work and far as the feedback I sure you can use a RC network to send feedback to the amp .
I will proceed and experiment with a RC network for feed back. Any suggestions on a starting point would be appreciated. Thank you both.
Glenn
This may be what I am looking for??? See Ron's comments. https://philcoradio.com/phorum/showthrea...edback+tap I'm going to try it.
Glenn
Hello Glenn,
This reminds me of the German radios from the late 50s early 60s I have restored. The Germans perfected the r-c negative feedback in every set they produced. If you look up the schematic for a Grundig 3198 or any model in that number range you'll see what I mean. You'll even find their warnings that if the opt is replaced the secondary wire connected to the feedback network must be the correct phase as was pointed out in the link above. But it works fine and it's a simple application.
Thanks RodB, I'll check it out.
Glenn
Hello Glen,
Yes I agree with Rod , Good luck Glen and let us know how it goes !
Hi Glen,
My stab in the dark is to:
  • Measure the full secondary resistance.
  • Measure from the leg that is grounded to the feedback tap.
  • Divide this resistance by the full resistance to get a ratio of tap resistance/full resistance.  These resistance
  • values will be quite low but hopefully the meter sensitivity and resolution is good enough to give you an
  • accurate ratio.
  • Duplicate the ratio with two 1 Watt resistors with the larger one being 100 Ohms.  Put the 2 resistors in series
         with each other and this pair of resistors in parallel, with the output transformer, with the "leg" of the lower resistance value on the
         grounded end of the transformer and the leg of the higher resistance value to the other connection to the loudspeaker.  The junction of
         the 2 resistors is the feedback tap.
Hope this helps.
I get the new transformer this week and will post the results. Thanks for the help!
Glenn
Hello GRG,
That is great news and Mr Fixr had some good advice
I was able to get a Canadian made NOS Hammond 125D new in box for $25 CDN!
Per Ron's comments in forum post  https://philcoradio.com/phorum/showthrea...edback+tap I used the attached schematic for the 46-1209 feedback replacement.  I started by using a 4.7 ohm (R201) and 68 ohm (R202) as per the 46-1209 schematic and found a sharp squeal at low volume.  Then I used an 82 ohm for the R202 and it worked great.  For fun I moved the R202 up to 100 ohms but the sqeal came back.  Returned to the 82 ohm and I am quite happy.
Thanks everyone who chimed in on this and a special thank you for Ron.
Glenn
$25 Canadian for an output transformer? Go to confession; that was a steal!!
As to "Mr Fixr had some good advice", even dead clock is correct twice in a day.
The interesting thing is that this does not appear to be negative feedback, it appears to be positive feedback. I may be wrong counting stages and figuring whether the feedback is negative or positive. I am used to seeing feedback being put into the cathode of a first audio stage. I will have to dig up some old Heathkit HiFi schematics. It is not common to find feedback circuits in "popularly priced" radios, but people were also not used to finding technology like the "Beam of Light" phono pickup that Philco used in the early 1940s or the GE RPX magnetic cartridge that came later which was the basis for modern magnetic pickups. These distort much less than crystal or ceramic pickups.
As always, I urge you to add an aux or phono input if one does not exist. Inputting programming from a computer (Lots of old time radio programs out there on the internet), MP3, CD plyer, etc., will make this set ROCK. I had a friend who used to input his guitar into the set for a mellow jazz guitar effect. Not loud because there was not enough gain but a nice sound.
There are currently 2173 online users. [Complete List]
» 1 Member(s) | 2172 Guest(s)
