I'm starting to restore a Philco 16X, I need spare parts. Please, help me find it
Threads: 24
City: Svalyava. Transkarpatia
Both output 6F6 radio tubes, when tested on a tube tester, turned out to be very weak in terms of emission. I suspect that there was a significant increase in the current of these radio tubes due to current leakage through the paper capacitors in the control grid circuit of these radio tubes. Of course, I will definitely change all the paper capacitors.
Sincerely Peter
З повагою Петро
Threads: 46
City: Lapeer, MI
State, Province, Country: USA
Great work, loved the video! Joe
Threads: 24
Thanks Joe. If you are interested in my videos, go to my YouTube channel, there are 225 more videos about our common hobby.
Sincerely Peter
З повагою Петро
Threads: 24
Philco restoration continues.... This week I repaired the speaker and replaced the output transformer... I suggest you watch the video. English subtitles
"Philco 16X Restoration, Part Two. Speaker and Output Transformer Repair
Video about speaker restoration and the method of determining the technical characteristics, calculation and selection of the output transformer for the wonderful antique American radio console Philco 16X from 1934"
[Video: https://www.youtube.com/watch?v=8sxszdqJzKE&t=575s]
Sincerely Peter
З повагою Петро
(This post was last modified: 03-22-2026, 03:33 PM by RadioSvit.)
Дуже цiкаво.
Threads: 24
Michael, how is the English subtitles? Ok, are there any problems?
Sincerely Peter
З повагою Петро
Mostly OK. Like, "диффузор" which you translated as "diffuser" - we here call it "cone."
Same as you still use "lamps" in your videos (not this one) whereas while UK uses "valves", we use "tubes."
But in general, it all is understandable, which is what counts.
Threads: 24
Thank you, Michael.
Sincerely Peter
З повагою Петро
They must have adopted the French term for vacuum tubes in the USSR, in France they call tubes "Lampes". Valves is what they call tubes in New Zealand, and Australia as well, I never understand why they called them "valves" as valves are a passive device, as vacuum tubes amplify.
The name came from the rectifiers (the first tubes) which did act as valves. And then they just kept it.
Thinking of it, the word "tube" is even less informative.
Mike;
The name "tube" is really colloquial for "Thermionic Vacuum Tube" although most tube manuals say "Electron Tube Manual". I think the British adopted the name from the "Fleming Valve" which was basically a detector diode, but when it came to picture tubes they called them "Cathode Ray Tubes" not "Cathode Ray Valves". I have also heard, and read the term "Kinescope" printed in service literature, even with American made TVs, but it was never universally adopted, picture tube was the colloquial term.
The favorite phrase that I heard for tubes, or valves, or lampes, was from Dave Jones of the EEV Blog, he called them "An FET with a pilot light."
Kinescope (Кинескоп) is the official Russian term for a CRT.
Threads: 24
I continue the restoration of the Philco, prepare the chassis for repair, clean it of dirt and conduct an inspection and revision of the volume of work that will have to be done. Perhaps I will shock many restorers with my method of radical cleaning of many years of dirt and rust...  But I hasten to reassure you - not a single detail has deteriorated, but only become cleaner. Sorry, but it has been a long time since I repaired a chassis with such a terrible amount of dirt. Yeah ... The scale, which I planned to replace before cleaning, after cleaning became like new.
"Philco 16X. Part three. Chassis cleaning and inspection before repair
In this video I will carry out preparatory work before repairing the chassis of the unique American radio console Philco 16X 1933...34. Namely, what methods I had to use to clean this chassis for a long time from many years of dirt and rust and what parts need to be replaced on it after a careful inspection and inspection."
[Video: https://www.youtube.com/watch?v=ty6H4sj3D3M&t=129s]
Sincerely Peter
З повагою Петро
(This post was last modified: 03-28-2026, 06:10 PM by RadioSvit.)
| Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM |
| hello Roy,
I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM |
| This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM |
| Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM |
| Roy;
Personally I would have left the asbestos alone if it were my set, but you can find a modern substitute that som...Arran — 04:51 PM |
| Looks like that might be the B- buss, so that would be correct.RodB — 01:32 PM |
| I noticed on the code 121 schematic the center tap for the 6 volt winding and hv winding are tied together. Is this corr...dconant — 12:16 PM |
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
My Atwater Kent 84
| Well getting around to restoring my AK84. Mike was a big part in me being able to snatch this one a few years ago. I won...462ron — 10:57 AM |
