42-395 low sensitivity, distortion issues
Threads: 1
City: Dubuque
State, Province, Country: Iowa
Recapped and aligned chassis can receive the 2 local stations with little else across the dial and even the local audio is somewhat distorted, can't be tuned clear. I left those few micamold type caps alone. Replaced the bad audio output transformer. Still improving my alignment skills but it seemed to have aligned ok. The loctal sockets have about all had that thin crumbly insulator fail but otherwise seem to have good connection. Any thoughts on what else to check? https://philcoradio.com/library/download...20Book.pdf
Threads: 226
City: Omak
State, Province, Country: WA
Hello dspy,
First of all, welcome to the forum! It sounds like you’ve gotten a great start on this set. Have you tested the tubes? Also, do you have any test equipment, like an audio signal tracer? That would be handy for figuring out if the issue is in the audio amplifier section or earlier.
What Rich said. I'd ask the same exact questions.
Threads: 1
City: Dubuque
Thanks for the warm welcome! I have checked and double checked the tubes and all test good now. I don't have a signal tracer but may be able to borrow one.
What kind of tube tested do you have?
Threads: 1
City: Dubuque
I have a BK 707, the loctal tubes are in the emissions section. I have a backup Philco tester as well, but also emission.
Well, that was what I was driving at.
You did not test them in the upper part, as loctals are tested for emission only.
You need to confirm good mutual conduction for all tubes.
Threads: 9
City: Roanoke
morzh Wrote: You need to confirm good mutual conduction for all tubes.
I will second that. Different tests, offered by different tube testers, have different uses. I use my emission tester (EICO 625) only for power tubes, where low emission can render a tube useless for producing power. For small-signal tubes I find my dynamic mutual conductance tester (Hickok 533) more useful. Bear in mind that no tube tester can tell you if a tube is good - it can only tell you that is is not definitely bad. Only the way that a tube behaves in the circuit where you are using it can tell you that it is good. Doing so may require specialized equipment (such as a quality oscilloscope or a laboratory grade signal generator) in the hands of an experienced restorer. That is why many of us have built up stocks of good used tubes.
Threads: 55
City: Roseville, MN
A set of mutually conducting tubes does wonders for radios.
Forgot who said it (sometimes attributed to Chuck Yeager, but probably not):
- A good pilot can fly anything that flies - and, with some difficulty, even some things never meant to fly.
That is, any radio design will work with a set of mutually conductive tubes. How about duds with no emissions or even no filament continuity?
Threads: 1
City: Dubuque
ok, should have access to a signal tracer Wednesday, scratching my head on the mutual conductance tester.
| And life just keeps getting more complicated. By dconant.
Dittos'Jimradio — 08:01 AM |
| hello david,
| Hello Everyone,
There are currently 1381 online users. [Complete List] » 1 Member(s) | 1380 Guest(s)
