Zenith 6S254 Intermitten Reception
>>> It does not play at first power up of the day most times.
So you have to turn it on several times for it to play?
Have you looked at the volume control?
(I am not blaming the power switch as you said the voltages are OK when stopping playing)
Threads: 55
City: Roseville, MN
When you have the problem the set goes quiet and the AVC drops to minimum. That tells me there's no, or very little, signal from the antenna.
When the ground is disconnected from the antenna does the problem occur? Maybe there's a strange ground loop. Usually a ground loop will result in interference or oscillation.
Threads: 89
City: Marion
State, Province, Country: NY
Volume control seems OK and I have sprayed it with Deoxit F5.
The AVC never varies much whether the reception is good or bad.
I will play the radio with ground disconnected and see how long it lasts.
Earlier this morning when I turned it on it was on the strong station and reception was bad. I turned up the volume to almost max and I could here the station with much noise. Currently the ground is disconnected tuned to strongest station in the area playing as expected with some noise. AVC voltage is -2.3. Off station AVC is -2.5 opposite what I would expect.
Threads: 55
City: Roseville, MN
With a strong station I expect to see -5 to -8 volts of AVC.
Threads: 89
City: Marion
That is what I thought. So does that give us a clue?
Where are you measuring your AVC, and relative to what?
Threads: 89
City: Marion
On the 6H6 tube pin 8. Pin 4 and 8 are tied together. Positive probe on pin 8 negative probe on ground.
Threads: 55
City: Roseville, MN
Is the gimmick made with stranded or single strand wire? Might want to replace it with a 5pf cap.
Threads: 89
City: Marion
Stranded wire. Where do I connect the cap. I assume osc section to ant section of tuning cap?
Threads: 55
City: Roseville, MN
The gimmick should have two wires connected. The cap leads go where the gimmick wires are soldered in.
What you are measuring is mostly voltage created by the Candohm divider between the 27 Ohm and 128 Ohm sections.
And NOT the AVC.
Threads: 89
City: Marion
When I first got the radio the gimmick was connected to the osc section and wrapped around the wire going from ant section to the 6A8 grid. Only one side of gimmick was connected. So not sure how to wire 5pf cap.
Threads: 89
City: Marion
Where do I measure the AVC?
I think the filtered AVC is C12/R5 connection. Which will be the same voltage as on the Grid of 6A8. (G4, the Grid cap)
Threads: 89
City: Marion
Ok. I get a decent swing of AVC on the 6A8 grid.
| hello Roy,
I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM |
| This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM |
| Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM |
| Roy;
Personally I would have left the asbestos alone if it were my set, but you can find a modern substitute that som...Arran — 04:51 PM |
| Looks like that might be the B- buss, so that would be correct.RodB — 01:32 PM |
| I noticed on the code 121 schematic the center tap for the 6 volt winding and hv winding are tied together. Is this corr...dconant — 12:16 PM |
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
My Atwater Kent 84
| Well getting around to restoring my AK84. Mike was a big part in me being able to snatch this one a few years ago. I won...462ron — 10:57 AM |
| The engine is a B&S 23 inch cast Iron holds 2 quarts of oil. The Generator is a 4 pole 1800 rpm mine was made in 195...David — 10:51 AM |
There are currently 1943 online users. [Complete List] » 2 Member(s) | 1941 Guest(s)
