Philco 42-350T Speaker cone
Hi there, is there a recommended source to buy a replacement cone for a Philco table top 42-350? Any idea what they cost?  Thanks for any info.
Sometimes a professional recone works out well and not that expensive........
This guy is a decent fellow and does fine work, reasonable last time I used him.
http://www.soundremedynj.com/
Yeah, Rich Stamer at Sound Remedy is the best. Icon_thumbup Icon_thumbup
Thanks guys, I'll get in touch and see what he says.
I recommend Nick Dorazio at thespeakershop.com in Florida.
Have had half a dozen speakers reconed/ field coils/voice coils rewound thru him and he does great work.
Another great recommendation!  Thank you.  I heard back from Rich Stamer and he said "The only limiting factor is the voice coil, minimum size is 0.522" I.D."  I have the broken voice coil from the radio and I measured it, it's a little over 1/2 inch in diameter so it might be within Rich's requirement.  Not sure.  But great to have another source to ask.  I'm on it.  Thanks again sdradioman!
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
Philco 38-2 Low Volume
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
Hi DConat, Generally, the lower the plate voltage the less negative the grid voltage has to be. Since the plates an...MrFixr55 — 09:27 PM
RCA WV-98c
If I had it in front of me, I would triy to trace the signal on one of the non-working functions. Try to trace and high...morzh — 08:21 PM
There are currently 1222 online users. [Complete List]
» 1 Member(s) | 1221 Guest(s)
