A little Z restoration Chronicle DONE
Threads: 310
City: Kings Park NY
Here is a little Zenith 6D 2620 I am currently working on
Problem is that no one has the decal for it. It also needs a new dial cover. I may create a mold but I may give in and just buy one at K-town.
Image(s)
AC: 4 DC: 1
(This post was last modified: 09-12-2014, 04:04 PM by
OldRestorer .)
Threads: 310
City: Kings Park NY
Gloves on, strip, gloves off. Wow that was quick!
Image(s)
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
1 veneer flaw and gone
Image(s)
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
Sealed the cabinet last night and grain filled today. May need more coats. these grains are deep.
I know, I know, I should be a hand model right?
Maybe for Lane Bryant
Image(s)
AC: 4 DC: 1
Threads: 147
City: Dallas, TX
If the dial cover is not cracked or warped you may try using automotive rubbing compound use a very small buffing wheel/pad or by hand works very well. the cover will retain its patina look and you will be able to see the dial well .save your money
Threads: 51
City: San Antonio, TX
What is your grain filler of choice? Also, what color are you using...it looks like it will give a nice darker contrast in the grain.
Charlie in San Antonio
Threads: 310
City: Kings Park NY
I will try that for the dial cover but it is kinda ratty for me.
I use Mohawk Grain filler and am happy with it once I dilute it.
Kirk
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
Got a little work done this morning. Taped her off and added the trim color.
Then stained the cabinet. No toner on this one. She is the same color already. Will let he dry and then clear a few coats. Someone I know is making me a decal for the front so hopefully that will work.
Image(s)
AC: 4 DC: 1
Threads: 551
City: Jackson, NJ
You never started collecting. It was hoarding all along.
(This post was last modified: 08-27-2014, 10:52 AM by
morzh .)
Threads: 310
City: Kings Park NY
I really didn't start hoarding. They are all in line for restoration. I will keep one of each model and trade or sell the rest and buy ones I don't have.
I got the clear on today and now to wait for the decal....
May be a while but I got that little chassis fully recapped except for one .0005 cap
I replaced one .07 with a .1, is that ok since I am out of .068
Image(s)
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
Here is the mouse house before and after. i did not do a super scrub down on this one.
Image(s)
AC: 4 DC: 1
Threads: 70
City: Linn Creek, MO
Quote: I replaced one .07 with a .1, is that ok since I am out of .068
Don't know what the application is but it will probably be just fine.
M R Radios C M Tubes
Threads: 551
City: Jackson, NJ
Chassis looks OK to me.
0.07 UF is probably OK to be replaced oth 0.1uF, but if you want informed opinions, show the sch link and pos #.
Threads: 310
City: Kings Park NY
Ok I am having an issue.
I am finished with the Chassis but the dial lamps are both out.
I checked everything and the only issue I see is that the 14C7 is dead.
Is this the tube that handles the dial lamps?
Here is the closest schematic I could find.
http://www.nostalgiaair.org/PagesByModel...025068.pdf
AC: 4 DC: 1
Threads: 551
City: Jackson, NJ
Well, when you say the tube is dead, does it also mean open filament?
With this pilot lamps will not light, or any other tube's filament for that matter.
Any open filament will keep the rest of them dead and pilots not lt.
(This post was last modified: 09-03-2014, 07:17 PM by
morzh .)
Philco 38-2 Low Volume
Both sch, the one you showed in the beginning and the one I see on Nostalgia, show 40K for the 2nd audio plate.morzh — 02:25 PM
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
I managed to get some more time on this.
Hi Mr. FixIT,
The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination.
Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages
Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
Hi DConat,
Generally, the lower the plate voltage the less negative the grid voltage has to be. Since the plates an...MrFixr55 — 09:27 PM
There are currently 1158 online users. [Complete List ]» 2 Member(s) | 1156 Guest(s)
