AK Model 42 Transformer Ground?
Not always. I have had the HV winding break down slowly and after a radio is finished just prior to shipping. That is why I suggest 15 min, even if it looks good at first. Too late after it is back in the tar.
350V on one side of this transformer sounds a little low. Depends on the primary voltage. I always make sure that mine will run at 120V.
+1. My Philco Tropic 42-720 seemed OK at first when I applied power after replacing the bad 6X5. 30 minutes later, it was smoking like crazy and the transformer was hot as...well, you know...
Philco 39-116 radio and remote
The transformer I located is from a Philco TV chassis, circa 1948. The part number is 32-8391 I do have the replace...Brad Winder — 08:59 PM
Philco 41-221 Restored
Hello Rod, Wow that radio looks great nice job ! Sincerely Richardradiorich — 07:39 PM
Philco 269 - 444 FIVE VALVE VERSION?
From what I can remember the model 444 "People's Radio" used a special tube/valve called a PenDD61, it was the...Arran — 06:54 PM
Nice Radioslford310 — 06:24 PM
Hi Chaz,  You may want to post the tubes used in your radio.   From Radio Museum, it seems that the set uses some ...MrFixr55 — 05:14 PM
Today my grandson and I finished the restoration of this Philco 41-221. It has had all the rubber coated wiring replaced...RodB — 03:19 PM
Hi Brad, I had no idea that the overheating was problematic in this radio.  Do you know the part number of the transfor...RichG — 03:01 PM
From the photo it looks the sockets are screwed and the front one does not even match the hole.morzh — 02:54 PM
Hi Chas a welcome, Perhaps we'll have to reverse engineer this to sort it. So let's start w/what tubes does it use? And...Radioroslyn — 12:28 PM
Hi Rich, From my experience, unfortunately it is not uncommon to find the power transformer in the 39-116 to be overhea...Brad Winder — 09:25 AM
