Threads: 23
City: Murray, KY
When replacing a Philco dial (this one's a model 80) what is the preferred way to attach the reproduction?
They are held on as you know by very small rivets. Drilling out the rivets is no problem but what do you use in their place? Will contact cement hold?
Thanks.
Threads: 92
City: Clayton, NC
If you want to avoid cracking the plastic dial, use small screws/nuts.
Threads: 530
City: Jackson, NJ
Short of what Tom's suggested, if you are set on using rivets, you have to extract the mandrel from a rivet and use the barrel flaring it gently with some tool. You cannot use a riveting tool.
Threads: 23
City: Murray, KY
(06-04-2015, 01:22 PM)TA Forbes Wrote: If you want to avoid cracking the plastic dial, use small screws/nuts.
Two good answers already. I think I'll go with the small screws and nuts. Thanks fellows.
John
