37-640 RF Deck
I finished the chassis on my 37-640, pulled the RF Deck, reinstalled it with new soft grommets, but it still seams quite rigidly held in the chassis. I am curious what electronic advantage was obtained by building the radio this way, reduction of microphonics ?.
Hank
Hank, I just think it was built this way to make life miserable for people trying to restore radios that had the RF deck. Curse the designer!
Jerry
David Grimes...curse David Grimes...he is responsible for Philco's RF units in most 1937 and many 1938 models...
but anyway...
The RF units were cushioned with gum rubber, yes, in an effort to reduce microphonics.
Ed (blacksmith) at Renovated Radios makes and sells the proper gum rubber cushions for Philco's RF units, and those will give your Philco the original cushioning it once had.
That said, yes, I too have often used grommets in place of the original rubber cushions. Black rubber grommets do not have as much "give" as gum rubber but they work well.
Philco 46-480 Cabinet Restoration
I have since gotten the cabinet stained and toned. I saw a video online of another guy renovating a 46-480, and he used ...jrblasde — 07:37 PM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
There are currently 2075 online users. [Complete List]
» 3 Member(s) | 2072 Guest(s)
