Westinghouse N 202 ?
Can not find anyinfo for this model. The case looks like a model H202 but chasis is not Icon_confused Five tube chasis with 6K6GT-6X5GT-6SA7-6SQ7-6SK7. Being new to restoring I have looked everywhere I can think of. Would really appreciate any help Icon_biggrin
Model number what you go by not chassi . There is a schematic @ http://www.nostalgiaair.org for a h202.
let me clear up- the wood case looks like an H202 the back cover says westinghouse N202 and the tubes are not those used in an-H202 and the schematic for the H202 is not even close to what is there.
thanks again Icon_smile
Ihave 5 other forums searching this . Find out if there is any info. Icon_rolleyes
Is this an American made radio? Reason for asking is that sometimes Canadian made radios have their own numbering system. 'N' is an unusual prefix for a Westinghouse. Is there anything about it that may indicate an export version?
The schmatic for the M102 has the same tube line up ect .
On my search i found out rca victor made some radios for westinghouse. Also some set used social security numbers of owners . I all so found out most set numbers started out with m or w . I registered with a new forum on my adventure a guy had a N202 trying to give away . Said it was set from H**l . Icon_lol When my regisration goes through i will try to find something out. Icon_rolleyes
Kent.
Thanks for the info Icon_biggrin beginning to think I was loosing it Icon_redface being new to rebuilding i tried all the resources i could find. will look up the M102. there are some numbers on the chasis will post later. Looks as if repairs made earlier? a lot of heat damage have not tried to power up yet recapping and resister change.
Icon_biggrin later
the schema for the M102 matches what I have. It is a piece of ####.Wiring is rubber and worse than a 41290 Philco, wire wound resisters checked 4 and all checked bad. Will save for a rainy day Icon_lol Here are numbers stamped into chasis "made in USA" 5a52----561158. Thanks for all the help Icon_biggrin hope this post will help someone else. Icon_biggrin
Sorry . did not have any luck . Reason the guy got rid of his same problem you have. Idid find a telephone # of a guy who redid one 1-800 - 595 -0191. Icon_wink
His name is Ben.
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 2147 online users. [Complete List]
» 2 Member(s) | 2145 Guest(s)
