Threads: 2
City: Florence, SC
I will be doing a FM alignment on a 9.1mhz IF frequency 51-1734 radio and would like to know if I can do it using an oscilloscope such as a Tektronix 2236 and a BK 4040 sweep generator with a Heathkit SG8 or do I need other test equipment?
Threads: 2
City: Florence, SC
I forgot to mention that I also have a VTVM and a DMM.
Threads: 267
City: Bandon
State, Province, Country: OR
I can't really answer your specific question but just in case you have not seen it there is an FM alignment procedure outlined in the service bulletin found in our library.
https://philcoradio.com/library/download...-final.pdf
Threads: 2
City: Florence, SC
Thank you,
I am concerned that the BK 4040 function generator has too high of an output for IF tuning for either AM or FM so I may go with something like a HP8656B and a B&K 415 sweep generator to go along with a scope such as Tektronix 2235.
Threads: 36
City: Roseville, MN
I've been doing FM IF alignment using just an unmodulated carrier and monitoring the FM AGC. That's exactly what the tuning eye is using. Most of the German made AM/FM radios have alignment instructions on how to use this method. After I restored a Grundig 3198 with excellent results I've been using it on FM radios ever since. Best part is you don't need an FM signal generator or a sweep generator.
