Threads: 3
I'm stumped with this set working OK on the station PB's, but I cant get the osc to work on the BC/SW push buttons. Is there a separate oscillator for the station push buttons? I know the coils are separate for the station PB's, but the BC osc coil and push switch contacts have been checked out OK. I'm sure this is a recurring problem, but I can't find a reference.
Thanks for some input, please
Dale
Threads: 266
Double check the switch that switches from the pushbuttons to the dial.
Threads: 3
Thank you Terry, I'll try looking into the switches.
Dale
Threads: 18
Agree that L and C on push buttons are dertermined upon tuning. As I understand it, you are having diffficulty NOT using presets. Try the paper test between the rotors and stators of the tuning capacitor, and of course the windings of the oscillator coil as well. You're narly there with this set!
Threads: 3
Correct, codefox. The oscillator does not work when the BC and SW button is depressed. I get stations only when the presets are used. I've confirmed the BC osc coil continuity is OK and "it seems the switch contacts all have the correct continuity", BUT I've strained my eyes confirming that. I don't want to completely remove the assembly due to all the rubber wire (or what's left of it).
Dale
