Philco 76 dual wire wound resistor value
Greetings,
Does anyone know the values for the smalller dual wire wound resistor in the Philco model 76 chassis? It is identified as number 29 on the numbered schematic and part number 3864.
I mushroom clouded the one you see here is I can load my photo correctly.......well I tried but the file is too large.Icon_sad
Wayne
The section which connects to ground to B- is 250 ohms; the section that connects between B- and the center tap of the 45 filament winding is 800 ohms.
See here:
http://www.philcoradio.com/tech/images/76.jpg
Thanks Ron. Much appreciated.
