  • 1 Vote(s) - 1 Average
49-905 Mica Disease-FOUND IT!
After finishing (or so I thought) my 49-905, It has now started to make a crackling noise on AM only that sounds like the dreaded Mica disease. From the schematic I don't see any mica caps inside the AM IF cans. Any ideas?
http://www.nostalgiaair.org/PagesByModel...013674.pdf
Eric
Lake in the Hills, IL
C301, 302, 304 and such - gotta be micas.
Thanks Morzh, I'll check them out.
Eric
Eric, the problem is that the caps are integrated into the plastic base insulator of the transformer. They are not separately replaceable caps but more like the compression trimmers found in older style IF's. Just silver coated sheets of mica riveted to the terminals. As the plastic ages it compresses and contact is lost between the silver and the terminals.
Morzh, are you saying that there ARE micas inside of those IF cans?
Eric
They are part of the base insulator that the terminals exit from.
So, short of replacing the IF can is there anything that can be done?
Eric
Years ago I fixed one of these, by drilling out the rivet, removing the mica sheets and replacing the caps with external silver micas. It was a lot of work but it did solve the problem. I know of no other way, because any IF transformers of this type construction have or will have the problem in the future.
I believe they are referred to as K-tran IF transformers. Do a Google search and see if anyone has better solutions.
This is what they look like inside:
[Image: http://i132.photobucket.com/albums/q18/b...aps/k1.jpg]
Well, it looks like it is possible to repair. I do have some other cans laying around I'll swap them first and see what happens. Could the noise be from one of the mica caps in the radio or is it most likely the cans?
Eric
If the noise is only on AM, then its probably one of the transformers. Of course it also could be a bad resistor, connection or loose tube socket, etc, but I assume you already checked the other possibilities.
If you wiggle the IF transformer and the noise changes or gets worse, then that pretty much confirms that its the problem.
I saw an article just about 3 or so weeks ago, a guy wrote how he deals with SMD, I think he was working with some Transoceanic.
Just look up the Silver Mica Disease on the net, you will find it.
I got it guys! I replaced the 2nd IF can with an exact replacement and the noise is gone. Icon_thumbup
I'm glad I had a replacement. I wasn't looking forward to digging in to replace the mica.
Once again the greatest radio forum on the 'net comes through.
Thanks again, Morzh and Mondial.
Eric
I think this is what you're talking about. It is really helpful.
http://www.ppinyot.com/if_transformers.htm
Eric
Yes Eric, this is it.
Eric, don't throw that old can away. It is one of the easier ones to cut out the old mica and place new caps on the outside. Save it you may need it. Of all the cans that I repair, that type was pretty easy to get a repair style figured for it.
Don
